Inventor Forum
'End if must be preceded by a matching if'
9 REPLIES 9
Message 1 of 10
shmartin89
1798 Views, 9 Replies
Iv attached a picture to show the error & my rule text. I have created the Parameters etc. & the statement includes if & end if. Cheers,Capture.PNG
9 REPLIES 9
Message 2 of 10
waynehelley
in reply to: shmartin89
If Parameter("HEIGHT")=152.4
Parameter("UC_PROFILE")="152.4"
EndIf
If you are finding usnderstanding ilogic difficult, have a go at the online tutorials.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 3 of 10
waynehelley
in reply to: waynehelley
** Use "End IF', not "ENDIF"
Pasting into IE erased the space.
Wayne Helley
Visual Studio 2022
Message 4 of 10
shmartin89
Cheers,
My text in the 'UC_designation' Parameter contains 'x's. E.g - 152.x152x23
Inventor recognises this as an equation, therefor the rule doesnt work. Is there any way around this without replacing the 'x's?
Message 5 of 10
waynehelley
when you created the "UC_PROFILE" Parameter, did you create it as a text parameter?
If not, in the parameters dialogue, use the drop down in the bottom left which by default says "Add Numeric". Select "Add Text" instead.
Wayne Helley
Visual Studio 2022
Message 6 of 10
shmartin89
Cheers Wayne.
This is the first time iv started using Rules. If you havent already guessed!
Sandy
Message 7 of 10
shmartin89
Do you know if there is a way in which rules can be run automatically? E.g Everytime the part is updated or saved rather then having to press iTrigger
Cheers,
Message 8 of 10
shmartin89
NVM. Iv added the rule into event triggers.
Message 9 of 10
waynehelley
I'm not that knowledgeable about triggers I'm afraid, as I have only really been creating rules which I need to run on command, but have a look at this...
http://inventortrenches.blogspot.co.uk/2012/01/creating-basic-ilogic-rule-with-event.html
Wayne Helley
Visual Studio 2022
Message 10 of 10
waynehelley
I just realised NVM stands for nevermind so mevermind my last post also!
Wayne Helley
Visual Studio 2022
