I'm trying to make an Ifeature which has a few ports, which depending on the application some ports might not be added to the part. So I made the standard setup with the 4 ports each as a separate extrusion, thinking I could just set the depth to zero using a table in the Ifeature. Howerver Inventor didn't really care for that.
Anyone know of a way to turn off features in an Ifeature. So for example I could insert the Ifeature and by default it'd have all 4 ports. But it could also be inserted and you could choose to turn ports 2 and 4 off.
