Inventor General Discussion
LT.Rusty
Message 1 of 5 (417 Views)
Enable BOM View?
417 Views, 4 Replies
01-13-2014 03:28 PM
So there I was, adding a BOM to a drawing, and I clicked on the "BOM view must be enabled" prompt for about the 40,000th time in my Inventor career, and it finally occurred to me to wonder why.
Why do we have to enable the BOM view?  Is there a benefit to disabling it, or just not enabling it in the first place?  If I had the BOM view enabled but no parts list, would that cause a rift in reality through which would come the ravening sluagh or something?
I'm not criticizing, I'm just curious as to the intent behind this feature ...
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
Curtis_Waguespack
Message 2 of 5 (413 Views)
Re: Enable BOM View?
01-13-2014 03:35 PM in reply to: LT.Rusty
Hi LT.Rusty,
Unless I'm misunderstanding the issue, you could edit your *.iam template(s) and go to the BOM editor and enable both the Structured and Parts Only views, and then save your assembly template(s) with the BOM views enabled, and then you wouldn't need to enable the BOM views each time you place a Parts List on a drawing.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
LT.Rusty
Message 3 of 5 (398 Views)
01-13-2014 03:41 PM in reply to: Curtis_Waguespack
There is no real issue here, and I know I could permanently enable whatever in my templates ... I'm just curious as to why there needed to be an enabled / disabled state in the first place.
It just seems to be much like the device pictured here:
Curtis_Waguespack
Message 4 of 5 (393 Views)
01-13-2014 03:50 PM in reply to: LT.Rusty
Hi LT.Rusty,
Haveing both BOM views enabled does come with a "price" to performance, as Inventor is required to index both views when the drawing is brought up. This might not be an issue for many people, but for folks that work with large assemblies having the ability to enable only one of the BOM views can help considerably.
I hope this helps.
Curtis
LT.Rusty
Message 5 of 5 (386 Views)
01-13-2014 04:00 PM in reply to: Curtis_Waguespack
Okay, that makes sense.  My idle curiosity has been - for the moment - satisfied.
Thanks!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
