Inventor Forum
Embossing Text
7 REPLIES 7
Message 1 of 8
318 Views, 7 Replies
Embossing Text
Is it possible to change the default text style from default ansi in an .ipt
Cory McConnell
BJ pipeline Inspection
7 REPLIES 7
Message 2 of 8
Sure doesn't appear you can now does it?
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Cory McConnell" wrote in message
news:0281933115A4107C7FE8D8D5EF87D62D@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 3 of 8
Also the little arrow beside the text orientation box is greyed out so one
can't rotate one's text.
Cory McConnell
.ipt
> Cory McConnell
Message 4 of 8
You can use the rotate tool to rotate the sketch box after you place the
text
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
news:D55313A2C967A60ADBD5E54FA9C47AC2@in.WebX.maYIadrTaRb...
> Cory McConnell
> .ipt
> > Cory McConnell
Message 5 of 8
Thanks, that works.
Cory McConnell
"Sean Dotson" wrote in message
news:6B180F094E97DBF42974FA9E5E45DD79@in.WebX.maYIadrTaRb...
> text
> Sean Dotson, PE
one
> > Cory McConnell
an
> > .ipt
> > > Cory McConnell
Message 6 of 8
Or just click on a corner and drag it around, or add a construction line and add a angle
dim. 8^)
Kent
> text
Message 7 of 8
speaking of embossing text... does anyone else find it absolutely IMPOSSIBLE
to apply a fillet to text created this way?
even a fillet of 0.001mm won't stick...
text created using the old express tools then import (while much more
fiddly) didn't have this problem.
Col.
.ipt
> Cory McConnell
Message 8 of 8
I placed an IV6 example in C-F under this title.... no problems here..... used
MC Zircon Demi font.
> Col.
> .ipt
> > Cory McConnell
Dennis Jeffrey
CAD Associates - Fort Wayne
Autodesk ASC
(260-432-9695 x 221
