I have tried a couple different ways to do this with little success. What i am trying to extrude or emboss (cut) the degree numbers and hash marks on the attached dwg. Like on a watch bezel. I imported that portion of this autocad drawing to my model onto a flat plane above the surface. is there a way to cut this all at once onto that surface?
thanks
Solved by Curtis_Waguespack. Go to Solution.
The hash marks are relatively easy to do (can use circular pattern), the text not all that much more.
I would start from scratch in Inventor rather than importing the AutoCAD.
Attach your *.ipt file here if you get stuck.
Hi slphantom ,
Attached is an example part that has an iLogic rule in it. If you edit Sketch2 and then run the rule it will find all of the open profiles, including the numbers, and then extrude them some distance, as specified by you. You can then edit the extrusion feature created by the iLogic rule and change the solution from Distance to TO, and choose the surface as the TO selection.
Note also that I pasted in the geometry from AutoCAD and then made it a sketch block, and then positioned/constrained it. But the text wouldn't extrude when in a sketch block so I then just exploded the sketch block, and then ran the iLogic rule.
Also, I just happen to have had this rule on hand for this kind of issue (see link), and there are a couple of other variations:
http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
That is so cool Curtis. I am digging into Ilogic more and more. thanks so much.
