Inventor General Discussion
Distinguished Contributor
Breeze104
Message 1 of 80 (596 Views)
Embedding Excel into Sheet Metal template
596 Views, 79 Replies
09-07-2012 01:07 PM
First off..Noob question... How do you embed (not link) an excel spread sheet into my sheet metal template.  The excel file is simple, 2 rows listing the A1=gauge and B1= decimal equivalent.
What I want to do with this is to get the gauge to show up in the iProperties description along with length and width of part.  The thing is I need colum A to show up in the iProperties (12GA) but colum B to be used for the sheet metal default thicness.
I keep getting this errorwhen I run my code.....
Error in rule: Gauge, in document: Part1
GoExcel: 3rd Party worksheet not found: "3rd Party:Embedding 1", Sheet: "Sheet1"
Code so far..
i = GoExcel.FindRow("3rd Party:Embedding 1", "Sheet1", "Gauge", "<=", iProperties.Value("Custom", "Gauge"))
MultiValue.List("Thickness") = GoExcel.CellValues("3rd Party:Embedding 1", "Sheet1", "B2", "B35")
So I need help with both the embedding and code.
Distinguished Mentor
swordmaster
Message 2 of 80 (557 Views)
Re: Embedding Excel into Sheet Metal template
09-10-2012 07:25 AM in reply to: Breeze104
Tried, to reply to your PM but having some problems with that
embedding the excel is not a problem
Have not looked too closely at your code yet
Came into the office this morning to a huge problem (not mine) which i have to solve, so I am a bit swamped right now. I will try to look at it later today
On a unrelated subject did you catch the new Doctor Who episodes?
Inventor 2010 Certified Professional
*Pro
jletcher
Message 3 of 80 (555 Views)
09-10-2012 07:32 AM in reply to: Breeze104
Is there a reason for using excel? Mine are all done inside ilogic....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Breeze104
Message 4 of 80 (550 Views)
09-10-2012 08:14 AM in reply to: jletcher
well I guess since I had it I thought I would embed it into my sheet metal template.  It shows that it is embedded in the browser, but I keep getting the error I posted.
If there is an easier/better way I am open to ideas.
swordmaster
Message 5 of 80 (529 Views)
09-10-2012 11:21 AM in reply to: Breeze104
I am trying to reply to your PM but i keep getting knocked back. Problem is that there are two Breeze104 id's out there. Don't know if you created both
Breeze104
Message 6 of 80 (509 Views)
09-10-2012 01:42 PM in reply to: swordmaster
I got the file embedded and I got the file to be seen by iLogic.  But I am getting an error on my last line of code...
i = GoExcel.FindRow("3rd Party:Sheet Metal Gauge Chart .xls", "Sheet1", "Gauge", "<=", iProperties.Value("Custom", "Gauge"))
i = GoExcel.FindRow("3rd Party:Sheet Metal Gauge Chart .xls", "Sheet1", "Gauge", "<=", Gauge, "DecValue", "<=", DecValue)
MultiValue.List("Thickness") = GoExcel.CellValues("Sheet Metal Gauge Chart .xls", "Sheet1", "B2", "B35")
iProperties.Value("Project", "Description") = Gauge "x" Length "x" Width
I want the out put to show up in the description like this .....   12GA x XX x XX, but it keeps asking for "End of ststement expected"
*Pro
jletcher
Message 7 of 80 (498 Views)
09-11-2012 04:37 AM in reply to: Breeze104
Change last to
iProperties.Value("Project", "Description") = Gauge & " x "  & Length  & " x "Width
Make sure to put a space between the x and the quotations.
James Letcher
Breeze104
Message 8 of 80 (489 Views)
09-11-2012 05:37 AM in reply to: jletcher
I knew I was forgetting something and I knew it had to be simple...I was ways seem to forget the little things... ;(
Thanks.
I keep getting an error...
"Error in rule: SheetGauge, in document: Sheet Metal (in).ipt
'Mild Steel Gauge Chart.xls' could not be found. Check the spelling of the file name, and verify that the file location is correct.
If you are trying to open the file from your list of most recently used files, make sure that the file has not been renamed, moved, or deleted."
I can't have spelled it wrong, because I copied and pasted the file name.
So I reworked the code…..
GoExcel.CellValue("3rd Party:Mild Steel Gauge Chart.xls", "Sheet1", "A1") = iProperties.Value("Custom", "Gauge")
GoExcel.CellValue("3rd Party:Mild Steel Gauge Chart.xls", "Sheet1", "B1") = iProperties.Value("Custom", "DecValue")
MultiValue.List("Gauge") = GoExcel.CellValues("Mild Steel Gauge Chart.xls", "Sheet1", "A2", "A35")
MultiValue.List("DecValue") = GoExcel.CellValues("Mild Steel Gauge Chart.xls", "Sheet1", "B2", "B35")
Thickness = DecValue
iProperties.Value("Project", "Description") = Gauge & " x "  & Length  & " x " &  Width
But I still get the same error…errrrrr
*Pro
jletcher
Message 9 of 80 (487 Views)
09-11-2012 05:49 AM in reply to: Breeze104
So you are no longer imbedding?
If not I need to see the rest of the code I don't see the part where you tell it the locatiion of excel file.
James Letcher
Breeze104
Message 10 of 80 (566 Views)
09-11-2012 05:55 AM in reply to: Breeze104
And I have figured out that the error I am getting is coming from this section of code....
But the file name is exactly the same the section of code above it so I am not sure whay it keeps erroring out
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
