I'm probably not interpreting what you are doing correctly, but I patterned
some radial lines, made an ellipse on one and trimmed it. Offset a couple of
workplanes and projected successive lines to them drawing and trimming the
ellipses and didn't see any errors. If you want to post what it is you're
trying to do exactly, I could see what I misunderstood.
~Larry
"Jeff Howard" wrote in message
news:DF055279A9F459D8BB68F5FC4C198765@in.WebX.maYIadrTaRb...
> File in CF.
> What I'm trying to do is set up a sketch with ellipse and radial lines for
> projection to new sketches which will be elliptical segments. The radials
are
> projected, an ellipse sketched using the radials and then trimmed. When
> trimmed the ellipse segment goes red (can't solve constraints?).
> Thanks,
> Jeff
