Sometimes in an assembly when I go to edit the part in place, I RMB and the "edit" is greyed out only on certain components?
Just wondering why this is?
Solved by mcgyvr. Go to Solution.
Solved by stephengibson76. Go to Solution.
@stephengibson76 wrote:
maybe you have it open in another window, you cant edit in place if its already open, I think
correct
Kevin,
I think I would give Stephen the Correct Solution credit rather than mcgyvr. Correct?
@Anonymous wrote:
Kevin,
yep.. so I accepted Stephen solution
