Inventor Forum
Edit drawing dimensions
9 REPLIES 9
Message 1 of 10
461 Views, 9 Replies
I got a new computer recently and installed Inventor 11. I found I could not change the drawing dimensions (It chanced in the Edit Box and shown the changes in the dimensions, but after click "OK", the Edit Box closed and the dimension did not change). I remember there were the similar problems before and I installed KB918118 fixed it. So I tried to install KB918118. But my computer shown a message saying my computer system is newer and do not need the KB918118 update.
So what I can do?
Thanks!!!!!!
Wei
9 REPLIES 9
Message 2 of 10
SBix26
Inventor version 11, or Inventor 2011 (version 15)?  What operating system?
Message 3 of 10
Cadmanto
Why are you changing the dimensions in the drawing as aposed to in the model?
Then the drawing would reflect the model changes.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 10
This is a duplicate post, please don't waste people's time by posting the same thing twice.
Message 5 of 10
mrattray
I think, out of all of the things that forum newbies do, double posts grind me the worst.
http://forums.autodesk.com/t5/Autodesk-Inventor/Edit-drawing-dimensions/td-p/3656184
Mike (not Matt) Rattray
Message 6 of 10
in reply to: Cadmanto
Add "Ref", "Typ" ...after dimesions.
Message 7 of 10
in reply to: SBix26
Inventor 11. Windows xp
Message 8 of 10
Sorry. I thought I posted it in a wrong board (AutoCad), so I posted it in Inventor Board angain.
Message 9 of 10
mrattray
You marked your other thread as solution accepted...
Message 10 of 10
I found the solution in the following link:
 http://www.westcam.at/datentechnik/de/autodesk-inventor-11-hotfix.html
It works!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
