Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Edit a read only file in the library
4 REPLIES 4
673 Views, 4 Replies
I wish to edit a file in the library   usig Inventor 2011 --  this is shown as read only
is this possible?   If so, how do I go about it?
4 REPLIES 4
john.laidler
Set a project active that doesn't designate that folder as a library.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
rdyson
in reply to: john.laidler
OR move the file to a different folder, make changes, move back
PDSU 2016
Many thanks -- a great help
Allan
in reply to: rdyson
Many thanks  for you help
Allan
