Inventor Forum
Edit a read only file in the library
4 REPLIES 4
AllanCheetham8388
666 Views, 4 Replies
I wish to edit a file in the library   usig Inventor 2011 --  this is shown as read only
is this possible?   If so, how do I go about it?
4 REPLIES 4
Set a project active that doesn't designate that folder as a library.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
rdyson
in reply to: john.laidler
OR move the file to a different folder, make changes, move back
PDSU 2016
Many thanks -- a great help
Allan
AllanCheetham8388
in reply to: rdyson
Many thanks  for you help
Allan
