Hello!
I'm trying to simulate the physics of a spinning top and hopefully this can be done in a way so that I can try different shapes and sizes to see how they would behave in reality.
In the attached zip you will find an example of a spinning top and a bowl on witch to spin. I'm sure there are better ways of doing this than what conclusions I have reached this far and so I have left the example assembly clean from defining gravity and any form of rotation or contact joints in dynamic simulation.
I would appreciate the help, the time spent for achieving this is to **** high 🙂
First thing I noticed - your Bowl is not grounded?
Rather than "clean" assembly - I would be more interested in seeing what you have attempted so far.
The CADWhisperer YouTube Channel
What I have experimented with this far is to add a spatial join between the spinner and bowl. I then added a 3d Contact for interaction. To get a rotation I added a cylinder inside the spinner (Not sure about that one). I need to add motion to the spinner witch decreases according to friction and what ever else would affect the spin of a real spinning top. But like I said and the reason for a "clean" file, if there is a better solution I much rather learn that one instead of a fix for the current one. At this point I'm not really sure of what I'm doing 🙂
I have attached a new file.
Have you done the "Bouncing Ball on Stairs" exercise in the Wasim Younis book? (It is actually done incorrectly in the book, but would help in explaining a solution.)
I do not have that book. Any other tip or guidance would be appreciated.
Did you ever get the book?
Sign up for a class?
Figure it out on your own?
Hi Action,
as JDMather suggested passing through a dynamic training would be the best.
You can find the book easily:
If you speak German too:
In this case you can consider to manage the spatial joint and its DOFs.
On the vertical axis rotation you can impart an accelaration law as imposed motion that would simulate the spinning moment force.
Then you can add the 3d contact and its setting (friction, damping, etc) and if they will be considered other external forces as gravity, the spinning top launching force, etc
Admaiora
