Inventor General Discussion
Member
lzsin_125
Message 1 of 7 (355 Views)
Dynamic Simulation
355 Views, 6 Replies
08-19-2013 07:54 PM
I am currently want to run the dynamic simulation of certain mechansim with simulation player. The mechanism is single DOF which consists of a crank and few linkages that controlled by the crank as well. So, when I try to run mechanism with simulation player the whole mechanism run in a very slow mode, it tooks me around 3 to 4 hours to complete few revolution although at the final time I had been set as 1 seconds. However, when I reduced my applied force at the crank to around 0.0X N, the mechanism run faster compared to the previous one. Since 0.0x N is very small and my desire force was 500N, but when I changed, it tooks long time to simulate. May I know what happened on my design actually?
JDMather
Message 2 of 7 (326 Views)
Re: Dynamic Simulation
08-20-2013 03:59 AM in reply to: lzsin_125
Attach your assembly here.
How many time-steps are you calculating?
Do you need to show each slide during calculation?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
lzsin_125
Message 3 of 7 (295 Views)
08-20-2013 09:47 PM in reply to: JDMather
The assemble is as attached.
100 time steps is enough for me already.
ya, I may need to view each slide during calculation.
Thanks.
Regards
Sin
JDMather
Message 4 of 7 (275 Views)
08-21-2013 03:25 AM in reply to: lzsin_125
Before moving to an advanced topic like Dynamic Simulation you should understand that an assembly file (*.iam) is simply a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and DS Joints) and is therefore useless without the ipt files.
Attach your entire assembly here.
Member
lzsin_125
Message 5 of 7 (255 Views)
08-21-2013 09:32 AM in reply to: JDMather
Hi JDMather,
Sorry for that, I have reattached the parts and assembly.
JDMather
Message 6 of 7 (243 Views)
08-21-2013 12:08 PM in reply to: lzsin_125
Have you installed all Service Packs for 2012?
Is there a reason you can't use an Imposed Motion.
Right click on Properties of Revolution3 and click on Edit Imposed Motion and Enable a Constant Velocity.
Member
lzsin_125
Message 7 of 7 (206 Views)
08-22-2013 06:15 PM in reply to: JDMather
Hi JDMather,
Ya, it is now perform on what I expect to, Thanks JDMather.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
