style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"mariox" <Hello
href="mailto:giovanni.maineri@luve.it">giovanni.maineri@luve.it> wrote
in message
href="news:f12dc8a.-1@WebX.maYIadrTaRb">news:f12dc8a.-1@WebX.maYIadrTaRb...
everybody, I recently installed a second processor in my IBM M Pro
workstation, but I see that when Inventor makes the drawing views, only 50% of
the CPU's power are used, in the task manager window, when one processor works
at 100% power the other one is idle. Do anybody else can tell me some trick to
sove this situation? Regards, Giovanni.
"mariox" <Hello
in message
"Kevin Schneider, Autodesk" <
href="mailto:kevin.schneider@autodesk.com">kevin.schneider@autodesk.com>
wrote in message
href="news:FB0AAD50DFFF3B26135862845EECFE52@in.WebX.maYIadrTaRb">news:FB0AAD50DFFF3B26135862845EE......
Open taskmanager and look for the Backahl.exe
process. Set its affininity to processor 1. You can leave Inventor's affininty
to both 0 and 1.
-Kevin Schneider
"mariox" <Hello
wrote in message
of the CPU's power are used, in the task manager window, when one processor
works at 100% power the other one is idle. Do anybody else can tell me some
trick to sove this situation? Regards,
Giovanni.
The tool in question is named IMAGECFG.EXE -- Image Config, so named because
Microsoft refers to application binaries in Windows as the "image" of an
application. To set processor affinity for an app, you'll need to run IMAGECFG
from the command line with the following parameters.
imagecfg -a 0xn <D:>\Path\program.exe
The "0xn" is a hex code that sets which processor to give the program
affinity to. For processor 0, it's 0x1; for processor 1, it's 0x2. The numbers
go up to 32 processors, but the progression of the mask is peculiar: 0x1, 0x2,
0x4, 0x8, then 0x10, 0x20, 0x40, 0x80, 0x100, 0x200, and so on.
Once you do this, the exe for the program in question will be changed
permanently, so it's a good idea to make a backup copy of the exe in
question before playing with this. Also, you cannot use IMAGECFG on
.DLLs.
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:8B9124A1EB7570457E0782E79DA4EA24@in.WebX.maYIadrTaRb">news:8B9124A1EB7570457E0782E79DA......
Kevin I noticed I had to do this each and every
time I ran IV. Any way to set this up as a default?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
wrote in message
href="news:FB0AAD50DFFF3B26135862845EECFE52@in.WebX.maYIadrTaRb">news:FB0AAD50DFFF3B26135862845......
affininty to both 0 and 1.
-Kevin Schneider
"mariox" <Hello
wrote in message
50% of the CPU's power are used, in the task manager window, when one
processor works at 100% power the other one is idle. Do anybody else can
tell me some trick to sove this situation? Regards,
Giovanni.
wrote in message
href="news:B44ED92BA4FDC29552E86B3FA92CF3B3@in.WebX.maYIadrTaRb">news:B44ED92BA4FDC29552E86B3FA92......
If you want to do this yourself with an app that doesn't normally support
it, you'll need to use a tool from the Windows 2000 Server Resource Kit
(Supplement #1). You can also find this tool in the \SUPPORT folder of the
Windows NT/2K Server CD-ROM.
because Microsoft refers to application binaries in Windows as the "image" of
an application. To set processor affinity for an app, you'll need to run
IMAGECFG from the command line with the following parameters.
changed permanently, so it's a good idea to make a backup copy of
the exe in question before playing with this. Also, you cannot use
IMAGECFG on .DLLs.
href="news:8B9124A1EB7570457E0782E79DA4EA24@in.WebX.maYIadrTaRb">news:8B9124A1EB7570457E0782E79......
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
wrote in message
href="news:FB0AAD50DFFF3B26135862845EECFE52@in.WebX.maYIadrTaRb">news:FB0AAD50DFFF3B261358628......
-Kevin Schneider
"mariox" <Hello
wrote in message
Giovanni.
