Inventor Forum
Dual dimensions in Drawings
12 REPLIES 12
Message 1 of 13
rthakare
5617 Views, 12 Replies
Hello.
How do I show dual dimension in Inventor drawing?
12 REPLIES 12
Message 2 of 13
IgorMir
in reply to: rthakare
Just like that. Please see the attached.
Igor.
Web: www.meqc.com.au
Message 3 of 13
rthakare
in reply to: IgorMir
I tried it but its not showing second or dual dimensions. Is there someting I am missing out?
Message 4 of 13
SBix26
Post your files (.idw/.dwg and .ipt), and tell us what kind of dimension you're trying to place, and what version of Inventor you're using.
Message 5 of 13
rthakare
in reply to: SBix26
Message 6 of 13
Rich.O.3d
like that?
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 7 of 13
kpadgett
in reply to: Rich.O.3d
Like what? What did you do?
Specifics would be nice.
Message 8 of 13
TheCADWhisperer
in reply to: kpadgett
What version of Inventor are you using?
Have you installed all Service Packs and Updates for your version of Inventor?
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-74C1A1AA-D993-4993-9047-BF8F3EB857C6
Message 9 of 13
kpadgett
in reply to: TheCADWhisperer
Inventor 2016, fully updated.
Message 10 of 13
ASI_Aaron
Depending on what you are dimensioning, you may have to go through the different Features on the Alternate Units tab in Igor's picture and set the dual dims format there.  His answer is correct.
- Aaron -
PDSU 2016
i7-5820k
Samsung 950 PRO NVMe 512gb
Quadro K4200
32GB RAM
Tags (1)
Message 11 of 13
mdavis22569
in reply to: ASI_Aaron
This is a post from 2012 ... brought back ...probably easier to start new one.
However..
Quick and simple, you need to set up a Dimension style
One that would show dual dimensions.
First go to your styles editor  under Manage.
Then create a new one, call it whatever .. Dual Dim
Then set it up how you want it to be
Mike Davis
Message 12 of 13
TheCADWhisperer
Once you get your Dimension Styles Standard set up the way you want in the Styles Manager -
click the Dimension tool and select the Standard you want to use.
Message 13 of 13
kpadgett
Thank you to mdavis22569 and TheCADWhisperer. Enough detail to point me in the right direction without being pedantic.
Kudo's to both.
