Inventor Forum
Driving Constraints with multiple sub-assy's
2 REPLIES 2
117 Views, 2 Replies
I have an assembly consisting of multiple sub-assy's (cylinders and actuators). Once I set each cylinder to stroke at the specified distance (which will be different between cylinders) - is it possible to "play" each driven constraint at the same time to see all cylinders/actuators in motion?
2 REPLIES 2
I understand your problem (and have a similar one)! Unfortunatley, I do not have an answer...
I do know that if you insert multiple instances of the same sub-assembly, all instances will be driven with the same constraints. However, I have not found a way to have them constained in the main asembly (for placement) and actuate, even if they are to have the same drive constraints.
I'm still working on it and if I have any luck I'l let ya know!!
Try out Animator on www.sdotoson.com.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"lwolsiffer" wrote in message
news:f185477.-1@WebX.maYIadrTaRb...
> Thanks
