"pkarolyi" <Please
href="mailto:pkarolyi@twmi.rr.com">pkarolyi@twmi.rr.com> wrote in
message
href="news:f189a8e.-1@WebX.maYIadrTaRb">news:f189a8e.-1@WebX.maYIadrTaRb...
help!!
I have an assembly containing two instances of the same
sub-assembly. (The sub-assembly is a cylinder with a 42 inch stroke). The
drive contraints needed are the same for both cylinders.
After
successfully constraining the first "instance" of the cylider in the main
assembly and setting the drive constraints for the cylinder, both cylinders
are actuated at the same time with the same stroke. (Which is great-the drive
constraints work like intended). However, after constraining the second
instance of the cylinder in the main assembly, the drive constraint for the
first cylinder are no longer solved, and are not solved for the second
cylinder either.
Anyone have any idea how to accomplish this or know of
any pit falls I should look for?
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:037ED9D79FAB6AB2150BBD729E13B49E@in.WebX.maYIadrTaRb">news:037ED9D79FAB6AB2150BBD729E1......
If you have 2 copies of the same sub in the assy
then you can only drive one of them. The same sub cannot act in
different manners in the same project. You will need to make a copy of
the sub and place it as a separate occurrence in the main assy.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
"pkarolyi" <Please
message
help!!
After
drive constraints work like intended). However, after constraining the
second instance of the cylinder in the main assembly, the drive constraint
for the first cylinder are no longer solved, and are not solved for the
second cylinder either.
know of any pit falls I should look for?
