I have generated a new plane on an axis, and now im trying to start a new sketch on the new plane. However, the sketch origin on this new plane is somewhere in mid-air. Is there a way to align the sketch origin to a point, or will i have to work from the point in mid-air? See attached pics for location of plane and the arbitrary point.
Thanks in advance
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Jim O'Flaherty
First of all - I don't really see the need for a new workplane - attach your file here when you have actually used it for something.
Second - that projected point is not "floating in mid-air) it is a logical perpendicular projection of the origin. I would use it as is - the orgin is the single reference. Or projec the line as a point where/how you created the workplane.
My recommendation would be to NOT fool with the coordinate system for this design.
I guess it depends on what the user is trying to accomplish (I was unable to open the attached pics until just now).
I do have to agree with JD as that point does seem to be the projected center point from the "vertical" tube, correct?
Is this not what you want to reference for the new sketch?
But on the other hand, if and when a sketch is created and you actually do need to adjust said sketch, redefining the sketch is the way to go.
Jim O'Flaherty
Hi! If you don't want Inventor to choose sketch coordinate system for you, you should consider using UCS.. You will always get X, Y, and Z the way you like it.
Thanks!
Thanks, this did the trick. Im going to send this to the persons who are responsible for training us with the software, cause they skipped over this function completely, and ive had need of it a few times now.
