Hi all, its been a while, returning IV user, so please bear with me. Question: I want all parts detailed on a spcific dwg to pull in the drawing number in the titleblock to their i-props. This way, I can reference the dwgs the parts are detailed on
in the master assembly parts list. I know there is a way, may have to hit the books!
Solved by brendan.henderson. Go to Solution.
Solved by SBix26. Go to Solution.
This would have to be custom programmed using VBA or iLogic, it seems to me. This is not a typical workflow, and a part could be used on more than one drawing-- now what?
Maybe I wasn't clear, I just want to list the drawing number the parts are detailed on in an assembly parts list. I have a temporary solution, which is just manually adding the drawing number in an iprop field that I can pull in to the assemblt parts list. I was looking for a way to automate this, but the more I think about it, I dont see how. When an individual part is created I have no idea what drawing I am going to detail it on. Thanks for the reply though.
I think this could be easily done with an iLogic rule that you run from the drawing, perhaps triggered by the save event. If a part ever gets accidentally detailed on more than one drawing, the last one wins.
For what it's worth, we avoid this issue entirely by making the part number = drawing number.
Totally agree with sblixer. Part/assembly number = drawing number, and 1 drawing set for each part or assembly number. It just makes it easier to find stuff working with a consistent number for all items.
We also include the drawing number in our Parts List. See graphic.
