Inventor Forum
Drawing(.idw) will not update upon .ipt change
3 REPLIES 3
jbelle7435
2243 Views, 3 Replies
I am having issues with this. I create the part. I create the drawing. I add the part to the drawing. I make a modification to the part and then I select update(Lighting bolt) and NOTHING HAPPENS. Even when I did the local update.
I will review the rest of the thread tomorrow as I am leaving Inventor for today but this is bugging me!!
I can only see the change when I close the drawing and re-open it as of now.
note: When I do hit the update button it does shown the change for a split second then goes back to its previous state. Why does it not stay the new updated version??
Inventor 2012
3 REPLIES 3
blair
in reply to: jbelle7435
Are both the drawing and IPT residing in your current Work DIrectory. The drawing my be outside of the current work directory and in a Library directory?
You don't have the "Defer Updates" checked in the "Documents Setting>Drawing"?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
jbelle7435
in reply to: blair
Not in front of it inventor until tm but not sure about directory stuff in the 1st part you stated so I will check on that.
I did see this is other threads about this "defer upate". I did check it and it did not work still. I will try again tomorrow though and see if any progress was made.
Inventor 2012
jbelle7435
might of been a fluke with this part I was working on. I started a new one and it was updating as per change to the .ipt file. Plus I don't have the defer updates checked. It is unchecked and works
Inventor 2012
