Inventor Forum
Drawing gauge points
7 REPLIES 7
Message 1 of 8
t_sheen
1247 Views, 7 Replies
I am trying to dimension a drawing and specify 2 diameters at specific gauge points; however I am unable to draw these on the drawing sheet. I have tried creating a sketch over the projected view; however this is not at all accurate.
Can anyone advise a way of creating them?
Please see attached a screen shot (drawn in AutoCAD) of what I am trying to achieve.
I am using Inventor 2008.
7 REPLIES 7
Message 2 of 8
CCarreiras
in reply to: t_sheen
"I have tried creating a sketch over the projected view; however this is not at all accurate."
Hi!
Before you hit the sketch button, first, select the view here you want to do the sketch.
If you don't select a view, the sketch will belong to the all sheet and its independent from the views
If you pic first the view, the sketch will belong at that view and associative to that view.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 8
t_sheen
in reply to: CCarreiras
I am aware of clicking the view I want to create the sketch on, however, I cannot project any of the geometry from the view to be able to click on a specific point.
When I click line and try pick a point I cannot pick anything, only draw in fresh air.
Is there another option to use other than project geometry (which doesn’t work)?
Message 4 of 8
CCarreiras
Hi!
I'm doing that in Inventor 2014 and it's working well: I projected geometry from view, draw lines, points, etc and later i can use them to anchor the dimensions.
Are You using Inv 2014? Already install the Service Pack 1?
CCarreiras
Message 5 of 8
t_sheen
I'm using 2008, perhaps this is not a feature in older versions?
Message 6 of 8
CCarreiras
Hi!
Maybe it's that, I can't tell, i've no access to this version.
My workaround:
In the solid, you can split the face to create the anchor point that you need to use in the drawing.
CCarreiras
Message 7 of 8
t_sheen
I have just discovered how to do it.
When selecting the lines to project you have to right click and click "done" this then allows the geometry to be used.
Message 8 of 8
CCarreiras
Hi!
Really!? In newer versions we don't need that "done"!!! (I work with inventor from 2010 version)
Cool!!! You find the way. Good job. Bye.
CCarreiras
