Inventor Forum
Drawing embedded logos
1 REPLY 1
335 Views, 1 Reply
Is there any way to position and use dimensions with picture in idw title block?
It would be nice to attach those same way as text boxes can be adjusted.
so there would be border (like text boxes, with constraints, dims etc) that could be dimensioned and that would not show on drawing.
1 REPLY 1
Curtis_Waguespack
Hi wisafin,
Unfortunately I don't know of a way to add dimensions or constraints to the logo image. The best method that I can recommend is to use a sketched rectangle to set the size, and then place and scale the logo image manually.
Note that you can use the Sketch Only button to hide the rectangle lines so that they do not show in the title block.
I hope this helps.
Curtis
