I hope it is not silly but is there any way to draw built in gears by gear generator in Inventor? I mean, I need to create a spur gear around a solid body and then it is gonna be processed directly onto the body during manufacturing.
Good day from Turkey and Thanks a lot for any help
The Design Accelerator, creates a IAM file to contain the gear assembly. Each gear generated inside the IAM is a IPT file and can be used in a IDW/DWG to produce a drawing.
Depending on your Project structure, it should be easy to find the gear assembly and corresponding gears.
