Inventor Forum
Draft angle????????
1 REPLY 1
270 Views, 1 Reply
Draft angle????????
can i do a cylinder draft instead of a cone draft, i need my radius on bottom to match my radius on top
1 REPLY 1
mcgyvr
2 ways.
#1- When extruding the origional cylinder you can select to have the extrusion go out in both directions instead of 1 and apply your taper there which will cause the middle of the cylinder diameter to be the max radius.
#2- Or you need to split (split command) the cylinder in half then apply regular face drafts to each of the newly splitted faces.
