2 ways.
#1- When extruding the origional cylinder you can select to have the extrusion go out in both directions instead of 1 and apply your taper there which will cause the middle of the cylinder diameter to be the max radius.
#2- Or you need to split (split command) the cylinder in half then apply regular face drafts to each of the newly splitted faces.
