Hi everyone! Realistic Appearance funtion just gives me the creeps!! Where and how the hell do I disable this function - COMPLETELY?! For crying out loud! There is NO patch for this stupid Autodesk - "Realistic Appearance" feature at all!
This feature from "Style and Standard Editor" just gives me the crash!! Registry configuration will do! I would like to "Grey out" this feature. I want this feature out of the story as if it werent there... I want it out of the door....
I am using Autodesk Inventor Pro + SP1 (64-Bit)
Thank you (Taking a deep breath)...
An easy way would be to change your Application Options --> hardware tab to Compatabiltiy instead of Performance or Quality. This turns a few things off and you won't see Realistic Apperance. (I like it a lot though)
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
You could also select "Shaded" from the: "View>Appearance>Shaded". This makes it look like older versions
