Thanks! That really helps as I'm still running win2K SP2, I'll upgrade first
to SP3 and hope for the best. I do have a Q4 900XGL so I'll take a carefull
look at it's drivers as well. Currently I have the 41.04 installed but in
home use I found that 41.03 were more stable... I think Inventor was last
tested with the WHQL 40.72 so I'll give those a try...
Ronald
"John Bilton" wrote in message
news:EF25DCE77BA93F89159FA253396B325B@in.WebX.maYIadrTaRb...
> Leo is right, in the middle of a big project is not good time to upgrade.
> On memory usage, I have discovered a few things that may be of use to you
> regarding memory usage/leakage.
> Windows 2000 SP2 leaks memory like a sieve (I think it must the the
Microsoft
> internal name for it), but SP3 is rock solid. On SP2, with IV5.3, take a
large
> assembly (1.2 GB RAM in use), zoom window, zoom all, rotate model, WHAM,
all 2GB
> of RAM are in use. IV6 on W2kSP3, 1.2GB RAM in use, does not leak,
creates
> drawing views without any problem whatsoever.
> Jury is still out on XP as I haven't had sufficient time to find out where
it's
> problems lie.
> Also the graphics card and driver version you use can affect the RAM
consumption
> by Windows, and the information on the Inventor Graphics Card link from
> support page details this quite well. Same big assembly with Q4 900XGL
uses
> nearly 200MB more RAM than with a Wildcat VP card. The Quadro is faster
though.
> John Bilton
