Inventor Forum
Display / Grphics Card settings
4 REPLIES 4
davef
558 Views, 4 Replies
I know - this has probably been asked many times.  My search yielded no clear answers, though.
In everyday use with Inventor - I'm pretty unimpressed with the display of curved surfaces.  I can live with the surfaces as they are now displayed, but I'm wondering if I can improve things by tweaking a setting.  I am using a gaming type card, which may explain some of this.  (Although I understand that gaming cards aren't so evil nowadays with DirectX.)  Specifically, I have a GeForce 660 Ti with 2 Gb ram.  Any advice on a setting (with the Nvidia control panel or in Inventor) to eliminate (or improve) ugly displays like the attached screen grab?
Thanks for any advice you can send my way.
Cheers,
Dave
4 REPLIES 4
blair
in reply to: davef
The quality setting in IV's Applications is about it. Check that you are on the most current Windows certified graphics drivers would be the other. Also chech that you are current on all Inventor SP's and hot-fixes.
ADSK is working on fixing a couple of graphics issues that have shown up in IV2014 that weren't in IV2013.
ADSK points the finger at Microsoft which points the finger at the graphics cards. It is better than before when we were stuck with OpenGL (at least in my mind).
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
pcrawley
in reply to: davef
That image shows a surface that's coincident with the outer face of a thin-wall solid right?  (Hard to see exactly.)
If it's just a case of "I don't like the way it looks", you could just make the surface (or the solid) not visible.  The solid will look fine on its own - or the surface - but not both together like that.  I had some iLogic somewhere that runs through a part making all surfaces not visible.  If you are interested I'll see if I can find it.
It doesn't seem to make any difference regarding the graphics card type for this particular problem - I see exactly that sort of weirdness on all sorts of hardware configurations from both ends of the price spectrum.
Peter
davef
in reply to: pcrawley
Blair and Pcrawley,
Thank you both for your help.  I will check for updates.
Pcrawley, you are correct.  I had a surface coincident with a solid.  I have about 100 hours of Inventor experience now.  This was just my second or third use of the thicken feature command and didn't realize that the surface would remain visible.  I need to experiment a bit and see how the thicken fuinction works. While I didn't pay close attention until your heads up - I just assumed the surfaces would be consummed by the thicken features.  Turns out that the surfaces weren't consummed and remained visable.  This may be just how Inventor works, or perhaps the surfaces weren't consumed by the thicken features because they were created with a shared sketch.  I'll play around with this to become more familiar with these tools.  Making the surfaces invisable solved the issue.
Thank you again.
-Dave
LT.Rusty
in reply to: davef
Surfaces don't get consumed by Thicken.  You'll just have to turn them off after you're done with them.
You can also use the DELETE FACE command, but then they'll be gone gone, not just invisible, and if you need them later you won't have them available.
Rusty
