Inventor Forum
Disappearing Pipe
3 REPLIES 3
fspialek
288 Views, 3 Replies
Disappearing Pipe
In a drawing I have multiple sheets to show different pipe runs in the same assembly. I create seperate levels of detail and suppress the pipe runs I do not want to show for each sheet view. Next I insert a view into a sheet and select a level of detail for that view. I only have one view per sheet. Here is my problem:
Say I insert a view showing only pipe run "A" into Sheet 1 of my drawing. Then I insert a view showing only pipe run "B" into Sheet 2. So on and so forth.
When I save the drawing it sometimes will prompt me to save the assembly as well. If I check 'yes' to save both the drawing and assembly in the same prompt, Inventor crashes. If I save only the drawing, the next time I save it still asks me to save the assembly. If I check 'yes' to save the assembly and 'no' on the drawing, the red lightning symbol appears on a few of my sheets. When I activate those sheets so that they update, the piping is missing, nothing else. I have found a way around this, but it is annoying and I would like to find a way to resolve it without the next steps.
To resolve it I activate my assembly tab. Then I activate each level of detail in the assembly, one by one and save each one. Then I go back to my drawing tab. sometimes the lightning bolt appears next to the sheets, but the piping does not disappear doing it this way. This happens quite often when I am saving my drawings and has been very frustrating, especially when my piping disappears along with any labeling connected to it.
3 REPLIES 3
cbenner
in reply to: fspialek
My question is:  Why are you using LOD to show a single pipe run?  Each pipe run is (or should be) created as a sub-assembly of the main assembly, and can be shown as such for detailing on a drawing sheet.
Esky99!
Have to agree with Chris on this one.
Sounds like you are going about your drawings incorrectly.
Each Sub Assembly can be detailed individually.
fspialek
in reply to: cbenner
Chris, I have recently started using Inventor 2015. The disappearing pipe issue does not seem to be happening anymore. However, I am curious as to the way piping should be handled in Inventor. For my drawings I create a single piping assembly. This assembly contains three separate piping systems within it- supplies, returns, and electrical conduit. Then when I lay out the drawings I simply turn off the ones I do not want to show and save it in a LOD. Maybe this isn't the right way to do it, but for the purpose of only having one pipe assembly is my guess. This method was given to me by a peer, so I would like to know if this is not a good way to use piping assemblies. Are you saying to create a separate assembly for each type instead of suppressing elements within a single pipe assembly? Regards, Francis
