Hello
I have a problem with Inventor 2013. The dimension lines have disapeared and I have no idea how to bring them back. I've been through all the dimension styles and layers to make sure I hadn't turned one off
All other drawings are fine and if I create another even using the same model it works just fine but I'd rather find out why than re-do the whole drawing.
Here's an example of the problem
I am not using 2013 yet, but if you do a print preview are they there?
Also, I know you have checked the new dim style settings, but did you look at these settings?
Thanks for the quick response
print preview and actually printing the file shows exactly the same result as the screenshot.
I also tried both of these settings to no avail.
I tried rebooting and I also tried opening the drawing on 2 other computers
You wouldn't happen to still have 2012 running somewhere to try this would you?
If so and it shows the extention lines I would say you uncovered a bug in the software.
Someone else with the same issue.
Thank you, I hadn't found anyone else with the same issue.
I also noticed that page 1 of my drawing is perfectly fine while page 2 is broken. I am starting over the drawing as it probably will be faster than trying to salvage the old one.
