It is possible to turn off the glyphs of the direct manipulation in inventor 2011?
Everytime I want to create any operation (extrusion, revolution... ) I see the glyphs and the tool dialogue and I am sorry but the glyphs are annoying me...
Thanks.
Solved by johnsonshiue. Go to Solution.
HI...
You're wright... redundant options...
You can't turn off the glyphs, but you can put the classic tool windows in auto-hide(RMB in the ribbon of the tool window)... in that way you will start to use more times the glyphs and then they will start to annoy you less and less (for me was the same and it worked)...
regards
Hi! You can restore classic UI by going to Tools -> Application Options -> Colors -> Interface Style at the bottom -> select Classic UI -> Apply -> OK -> restart Inventor.
Please note that once you have done that, you will lose all the benefits provided by Ribbon UI and all the prior customization or configuration in Ribbon UI will be lost unless you have exported the setting to an xml file.
Thanks!
