I am really new to Inventor and with reading over this and other message boards, have been educating myself.
I have run across a situation that I have not been able to find having been previously asked.
I have attached the file of what I am working on.
I have 2 dimensions to the implied intersection, but how do I put the dimension when there are 2 implied intersections?
Such as along the bottom of the part.
Thank you very much for your help.
Solved by JDMather. Go to Solution.
Select angled line.
Right mouse button - intersection
Select horizontal line
Select other angled line
Select horizontal line a second time
click to place dimension.
Thank you very much.
Worked perfectly.
AS A HELP I'm attaching a small video that helped me when I was trying to learn and have referred to it over time as I use implied so infrequently. Covers doing dual implied.
