Inventor Forum
Dimensioning pre-radius
4 REPLIES 4
166 Views, 4 Replies
I have two parts coming together at a 20 degree angle. The corner has a 3/4" radius applied to it. I need to be able to dimension to the corner before the radius was applied. However, I have to show it with the radius.
How do i extend lines out to a cross so that I can dimension to the true corner?
4 REPLIES 4
http://www.kwikmcad.com/iclips/avi/intersection.zip -- Sean Dotson, PE (AICE) RND Automation & Engineering sdotson.com mcadforums.com "kellyhoyer" wrote in message news:17472546.1110309638680.JavaMail.jive@jiveforum1.autodesk.com... > I have two parts coming together at a 20 degree angle. The corner has a 3/4" radius applied to it. I need to be able to dimension to the corner before the radius was applied. However, I have to show it with the radius. > > How do i extend lines out to a cross so that I can dimension to the true corner?
Create a sketch.
Sorry. I understood it as you wanting to show cut stock.
See Sean's post.
Once again, thank you.
Sean
Your awsome.
