Inventor General Discussion
Distinguished Contributor
justinpcaris
Message 1 of 5 (3,121 Views)
Dimension Arc Length
3121 Views, 4 Replies
07-18-2011 08:59 AM
I would like to dimension the arc length of a radius in sketch mode and i was wondering if this is possible. I am using Inventor simulation 2010.
JDMather
Message 2 of 5 (3,115 Views)
Re: Dimension Arc Length
07-18-2011 09:59 AM in reply to: justinpcaris
Techniques for controlling arc length via parameters have been discussed here in the past - if you can't find the solution post back and I'll see if I still have an old file example.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
PaulMunford
Message 3 of 5 (3,064 Views)
07-19-2011 05:45 AM in reply to: justinpcaris
I put together a post on this that you might find usefull.
http://cadsetterout.com/inventor-tutorials/how-to-measure-dimension-and-specify-arc-length-in-sketch...
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
justinpcaris
Message 4 of 5 (3,044 Views)
07-19-2011 07:35 AM in reply to: PaulMunford
Awesome thanks for the help
PaulMunford
Message 5 of 5 (2,612 Views)
03-28-2012 11:47 PM in reply to: justinpcaris
You can now dimension Arc Lengths in sketches in Inventor 2013
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
