Hi guys,
English isn't my native language, so bear with me. 🙂
I am trying to design a kind of a modern version of four barrel derringer. As you can see in the pictures below, the hammer has a rotating disc on it with a firing pin. When the hammer goes back, disk if supposed to interact with the back piece ( not sure what's the right English word for it ) and rotate 90 degrees, so that the firing pin would be positioned to strike the next round.
Yet somehow I don't feel right about the way I designed it. Even if it won't get stuck, it might make the trigger-pull rather hard and awkward...
What do you think about such design? Maybe you'd have better ideas about how to make the firing pin turn?
Thanks!
patent of an old derringer:
Not seeing the pictures.
@mpatchus wrote:Not seeing the pictures.
They show up here - but I have been having trouble off-and-on seeing pictures (even ones I attached) on the forum lately.
I would use Dynamic Simulation to analyze the mechanism - but that is an advanced topic that would probably be too difficult for that assembly to cover on a forum.
That thing will kill whoever shoots it. The partial chamber will not support the case head of the cartridge, and it will literally blow up in your face.
Don't worry, it won't be shooting real ammo. 🙂 This will be special 15x90mm cartridges with OC ( pepper spray ) and a .22 blank round in the back to propel it.
.22LR has a pressure of up to 25,000 (yes, that's twenty five thousand) PSI. That's for a standard loaded round, I'm not sure how that translates with a blank but, I would make sure to do a lot of safety research here before you end up seriously injuring yourself or someone else.
Having said that, it is a clever idea. 🙂
No, no, the blank round is much weaker then that, basically its only a primer without any gunpowder.
By the way, there already is a similar product on the market, only 13x60 with a centerfire primer.
Well, it's your choice... I know there's no way I would pull that trigger.
By the way, there's only about 1/2 of a grain of pistol powder in a standard 22LR load...
