I have a 3D solid model in Design Review (DWF file) that I can orbit around and is functional. Is there a way I can import this 3D model straight into Inventor?
Solved by JDMather. Go to Solution.
I recommend that you request a solid part file from the owner of the Intelllectual Property.
There is probably a reason why the source (or your teacher) gave you the IP in dwf format.
Ok I tried to open the file but it said "file contains no markup 2D data, would you like to open this in design review"? I selected no, but the file still did not open in Inventor.
You can't open a 3d dwf in Inventor - only 2D.
