We have recently been consolidating our network drives, and moved our Design Data folder from one drive to another. Since that, we set up our new CAD stations with fresh installs of Inventor 2013 Pro. In the file paths, we set Design Data to the new location. However, Inventor is still looking to the old drive, which is no longer there. This is messing up a lot of things, as you can well imagine. This is what we see whenever we open an existing Inventor file, OR one of our templates. How are these embedded into the files themselves, and how can I force Inventor to see the new location?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
Does Frame generator require Excel?
Chris Benner
Got it! Default project file was still pointing to the old Design Data folder. D'oh! I knew I was short of sleep today, dut dang!
Chris Benner
