Hello everyone,
I am a newbie and trying to figure out a way to rescale an object because I found that it is too big for my experimential aparatus, but I want to retain the size of the holes in the object (they are not just cylindrical holes, rather with some structure). I have tried deriving the .ipt file but couldnt find an option to chose which structures not to rescale. Is there anyway around this? Or should I just redesigne the whole thing?
Thanks 🙂
Inventor is a history-based parametric modeler. That means it is easy to just edit your parts to change their size if you use good modeling practice. Do you need to keep the old part that does not fit? If you do, make a copy of it and edit the copy.
If you did not build your model part while planning for future modifications, make a new one using what you learned from your first model.
The derive function will remove all the features from your model browser. You will still be able to edit it, but only by creating new features, not changing existing ones.
Post your part and desired changes and someone may take a few minutes to review it for good technique. ALso list your version of Inventor.
Steve Walton
I think it can be done but a bit cumbersome for sure. You first need to derive the part with the scale you like. Then use Delete Face -> Heal command to remove the holes in the derived part. Next, you can derive the same source part again as a surface body. Next, use Sculpt or Split to remove the material.
Thanks!
