Inventor Forum
Derived parts and iParts
2 REPLIES 2
cadcamm99
432 Views, 2 Replies
I have a part that was derived from an assembly.  However now I need to make this part have different center dimensions.  Is there a way to make a derived part into an iPart without creating more parts?  Please see attachment.
I am using Inventor 2012.  BTW the part is more detailed than I am showing in the attachment.
2 REPLIES 2
coreyparks
in reply to: cadcamm99
Can you recreate this using multibody parts?  If not can you derive the assembly without the tab and then model the tab in later so that the length become editable inside an iPart?
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
cadcamm99
in reply to: coreyparks
I originally had multi bodies but then I realized that the insert was used in other parts so I had to create two different parts.  Also, the main part and the insert are different materials. I might try it modeling the other details in the derived part.
