Inventor Forum
Derive Style is always a Surface
3 REPLIES 3
CAD-One
268 Views, 3 Replies
I have ipt file that I am trying to derive into another part file. The "derive style" is set to surface only. solid icons (top most row icons) are all disabled/greyed out. But actually the part i am trying to derive oesnt have any surfaces.
Why does inventor force the derive to be surface only?
If i continue to dereive, I am seeing that the "move bodies" icon is also greyed out.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
3 REPLIES 3
CAD-One
in reply to: CAD-One
Let me give more details so it give better meaning to my question. I download a step/iges format of a PEMnut from  a website. Open it in inventor and save it as an IPT file. Its all fine till this time. I can see that there is 1Solid body. Just to make sure that its really working, in that same PEMnut file  i create a circle and extrude a little cylinder (With new body option).  Now I see 2 solids. Now that this is working fine, I delete the extruded cylinder feature and save this file.
In another sheet metal file, I am trying to derive this PEM nut ipt file into a sheetmetal part. The problem I am having is, after I bring the PEMnut into the sheetmetal part, its always a surface body and not a solidbody. I prefer it to be a solid body.
I tried editing the derived style. But the sold related buttons are greyed out. Why? I know there is a solid in the source file, then Why this strange behaviour?
Anways, Can one of you try deriving a PEM nut (say part# BSO-832-22ZI) into a sheetmetal part and let me know what you find out? Do you see anything different from me?
Thanks in advance.
C1
AutoCAD 2020
alessandro.gasso
If I’ve understood correctly your question, you cannot derive a part as solid body in a sheet metal part that already contains a solid body, because the sheet metal cannot be a multi body part.
I hope the attached video can clarify what I’m writing.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
CAD-One
in reply to: alessandro.gasso
Ale,
You have understood my question perfectly. Thanks.
Thanks for clarifying with this video. Looks like I should switch the Sheetmetal to a Standard part.
Too bad we cant have a Multi body in sheetmetal yet. Practically we install metallic inserts (PEM inserts) onto sheetmetal parts. This is a makes the PEM insert permament attachment to sheet metal. Typically we dont want to use a assembly modeling for this. Instead prefer to keep it a part level.
C1
C1
AutoCAD 2020
