The text is 1.5 x the standard text height. You can select it and in the context choose
to Edit it.
You could also set up another standard to use with a different text height to use when you
make your views I believe.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"DWP"
wrote in message news:f18c442.0@WebX.maYIadrTaRb...
> Second try?
> The detail view circle designation letter displays too
> large. Is it possible to edit the text height?
> TIA,
> DWP
