Open your ipart or your template. Go to Format> materials. Set up your new
Material here. You can find info about alot of materials at www.matweb.com
. (The units are in Metric and you can't change that - Autodesk states that
all Material Specs are in Metric??!?) Set your rendering style if you want
and exit. Open the opposing file, and go to Format> Organizer. Browse to
the original file, select the material you want to copy, click copy, and
exit out of organizer. Your Material will be in the properties "Physical"
tab pulldown.
Is this what you wanted?
Cory McConnell
BJ pipeline Inspection
"Svein" wrote in message news:f11fc31.1@WebX.maYIadrTaRb...
> Hi. I had to post back:-(
> Didn`t find what I was looking for.
> What I want to do is to make\define new materials to add to the parts in
IV6 library\content library
> and save it to the template file so that I can add it to library files
later also.
> Regards Svein
