Is there a way to set the default material in Frame Generator? I have a custom library for Content Center so I can modify that if needed. I would like structural members to default to ASTM A36 for example.
Inventor Pro 2013 (product design suite)
When I created Unistrut beams to use in my frame generator I created both carbon steel and SS.
They both come into the frame with the respective materials as I had when I published them. So I am in agreement that if you want a custom material you are going to have to republish the beam pieces you want in the material you need.
make sure the section shape/size is available in material, else you will have trouble buying it.
