Inventor Forum
Default location for templates in Inventor 2013
19 REPLIES 19
Message 1 of 20
RogerCamp
9153 Views, 19 Replies
I'm having problem changing the default location for templates in Application Options of Inventor 2013. If I set the location to a folder in my server, the template files aren't showing up. It's like there's nothing there. I've never found this problem before. The templates are shared on the network, so it's the same for everybody. Now it's necessary to everyone copy them locally, which is not the best practice in my opinion. Is there a solution to that problem?
19 REPLIES 19
Message 2 of 20
mflayler2
in reply to: RogerCamp
Check your settings in your project file.
Project File trumps Application Options.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 20
RogerCamp
in reply to: mflayler2
Hi Mark! Thank you for you reply.
Unfortunately it didn't work.
I set my project file to use a template on a network folder, but when I try to create a new file, the window takes like 4/5 seconds and shows me as seen bellow.
Message 4 of 20
rw_GHamilton
Has anyone came up with a solution for this? I am having the same trouble.
Message 5 of 20
cmbronder
in reply to: rw_GHamilton
I apologize for the inconvenience this problem is causing you.  We are able to reproduce this problem and it will be forwarded to development.
As a possible workaround, can you map the network server location to a drive letter on your local machine?
For example, using Windows Explorer's Tools->Map network drive... set Q: to \\networkserver\c$.  Then use "Q:\" in the Application Options Default Templates file path.
That workaround enabled me to get the File New dialog to display the templates from a networked location.
Clare Bronder
Autodesk, Inc.
Message 6 of 20
danzco
in reply to: cmbronder
Just wanted to bump this thread; we are having the same problem here.  The mapping a network drive is a bit of a kludge solution that we would rather not have to implement for the long term.
Message 7 of 20
RogerCamp
Thank you Clare for your reply. Unfortunately this solution doesn't work quite right for us as the template folder is not in the root of the drive, so I can't map it. I'd have to change it's location which is not what we want.
I hope Autodesk can make a hotfix for it.
Message 8 of 20
mflayler2
I actually tried mapping from the UNC path today and did not experience this problem.  I wonder if it is something environmental...but then again why would it do it in 2013 and not 2012...hmmm
Message 9 of 20
I have the same issue!!!
Robot Frustrated
Setup:
  • Path Used "\\SERVERNAME\Cad_Sys_Resources\Inventor\2013\Templates" (Folders for setup resources have no advantage to being on a mapped drive, in fact I feel that mapped drives are like using relative path and therefor BAD, drive letter designation may change).
  • Server did not have indexing on (if that does anything).
  • I have admins to the location.
  • Local Domain Server
Issue:
  • I can't see, select or use my Inventor Templates.
  • How embarrassing as a CAD Manager!
Resolution:
  • Map the network drive.
  • Once mapped you can use the full network path and it works! Why not when it’s not mapped?
Further Investigation:
  • Review if Templates are still functional when the Network Location is mapped as drive and then drive mapping removed?
Message 10 of 20
danzco
in reply to: stewart.carberry
Wow, I would not have thought to try that.  Yes, indeed it does seem to still work after removing the drive mapping.  I have not yet tried restarting my computer though; I'll let you know tomorrow.
Message 11 of 20
stewart.carberry
in reply to: danzco
Sounds Positive!!! Regards, Stewy
Message 12 of 20
That's a Roger Stewie. It works!
Thanks for your help.
Maybe Autodesk can fix it soon, so we don't need to use any workaround.
Roger
Message 13 of 20
danzco
The workaround does seem to hold water pretty well.  The most consistent way we've been able to make it work is as follows:
  1. Map network drive to some unused drive letter
  2. Update the template locations on the File tab in the options dialog to point to the mapped drive.
  3. Apply the changes, reload your project file, then check that the templates are appearing correctly.
  4. Update the template locations on the File tab in the options dialog to point to the network location.
  5. Apply the changes, reload your project file, then check that the templates are appearing correctly.
  6. Unmap the drive.  Everything should still work.
Some of our users were able to skip steps two and three.  YMMV.
Message 14 of 20
theodore.schindler
in reply to: danzco
I've experienced this same problem.  For me the server name was case sensitive.  By correcting the case (upper case to lower case name for the server), the problem went away.
Message 15 of 20
Add one more to the list of users who had to switch to using a mapped location for templates...
Mike (not Matt) Rattray
Message 16 of 20
Just wanted to update this thread so that everyone is aware that Update 1 for Inventor 2013 is available. This update addresses this issue.
Download the Update at the below link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19656800&linkID=9242019
Nathan Chandler
Principal Specialist
Message 17 of 20
CADDapult
in reply to: innovatenate
FYI: Dead link for the sevice pack("Page not found").
More of a curmudgeon by the hour
Message 18 of 20
SBix26
in reply to: CADDapult
Try here.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 19 of 20
Thank you for letting us know.  When you say "Dead link for the sevice pack("Page not found").", what did you select to get this message?  Was it the "New" file item?
In my test with Update 1 for Inventor 2013, specifying a UNC path, e.g. \\ourserver\testing\templates, for the template location in the Application Options, then selecting the "New" button does display the templates in the "Create New File" dialog (after about 50secs first time, then 10 seconds subsequently).  A new file could then be successfully created.
Any details you could provide would be great.
Thanks.
Message 20 of 20
AdrianT
in reply to: danzco
I've had the exact same problems as I use two different network drives and also my local disk (C: drive) for renaming. In my opinion it can work to have default templates and data styles etc on a network but it causes a massive loss of speed. I've been struggling this morning and come to realise Inventor works best with them on your C: drive. I believe Vault cures these issues, so I'm told.
