How do you set the default IDW template used when you select 'New Drawing?'
Solved by blair. Go to Solution.
You can have many templates. you set the location of them in the Tools\Application Options\Files. If you use the "New" as shown in this image, Inventor will automatically default to the file named "Standard.idw". Otherwise, click the little arrow to the right of New, and you will get to the list of available templates.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I had already followed the instructions above, without success. Inventor was looking for "Standard.dwg" instead of using my "Standard.idw". I had to change the "Default Drawing File Type" on the Drawing tab of the Application Options.
