Default Content Centre location and template location changes to Local machine settings (Inventor's default settings) instead of defined location. This happens whenever user re-open the Inventor. File location changes to Inventor's default.
Do the folder settings in your master project file match where you have your CC and your templates?
Yes, the location of Templates and CC,in projects, are defined as where I want, but the settings changed to Inventor's default settings.
Refer Image attached. These are reqd. location.
Yah, once in awhile inventor will do this, mostly after a crash. Just reset the project path. Sorry, but as of now I am unaware of any fixes for this seeming random event. Thankfully it does not happen frequently. if it is happening frequently as you seem to imply it is on every opening then go to Get Started tab > Projects and set it in there. The one chosen on opening as the screen shot suggests does not always set a perment path.
Yes, I agree. This has happened to me at times as well. I haven't heard of a fix either as of yet.
You just have to restablish your connection with the master project file you use when you first start your Inventor session.
