Inventor Forum
Def Points layer
5 REPLIES 5
jrittenhouse
446 Views, 5 Replies
Def Points layer
How can I delete a def point layer after the program says i can not?
5 REPLIES 5
john.laidler
in reply to: jrittenhouse
Defpoints in 'Inventor'?
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
jrittenhouse
in reply to: john.laidler
Def points in AutoCAD.
john.laidler
This is the 'Inventor' group.  But why would you want to delete 'defpoints'?  You can't delete that layer anyway, AutoCAD uses it for certain objects created.
John Laidler
ampster401
one way is to rename defpoints then purge.
john.laidler
in reply to: ampster401
Yes, you can rename the layer.  But once a dimension is placed, defpoints is created again.
Best option, leave it alone.
John Laidler
