Inventor Forum
Date Format Change
21 REPLIES 21
Message 1 of 22
BrianForeman7947
12019 Views, 21 Replies
Date Format Change
Company standards for documentation require a different date format in our mechanical drawings.  I have seen the various posts how Inventor uses the O/S system date format and applies it to the file.  The issue is we don't want to change the O/S date format.  It changes date display on EVERY program on that computer, including Windows Explorer.  That means the date column on every program's open file, save file, etc. now has the new date format.
Is there another way?  Can this be changed so that a user can't mess this date format up by simply changing his settings to something else (or back to default)?
21 REPLIES 21
Message 2 of 22
mcgyvr
in reply to: BrianForeman7947
Sure just change your company standards. Problem solved.
Message 3 of 22
Yeah, I thought of that.  That may be more difficult than what I am asking.  Office Politics and the Old Guard (the ones who say "It's always been this way").
Message 4 of 22
mcgyvr
Companies that can't adapt/change will fail.
Inventor uses the system information
You could simply prompt for the date on drawing creation (date in whatever format would then be manually entered).
I do this simply because we were redoing a bunch of drawings when I first started using Inventor (old Autocad drawings) and I tried to make sure the date was the date that the Autocad drawing was.
But I still say that unless there is a darn good reason to have a different format it is much easier to simply change company standards to comply with the current technologies. It's 1 change now or years of manually entering dates in a specific format.
Message 5 of 22
msklein
in reply to: mcgyvr
mcgyvr,
the answer I always use when I get that comment is "just because you've always done that way doesn't make it right"
Message 6 of 22
bobvdd
Brian,
You could add following iLogic rule to your part and assembly templates and make sure that you trigger the rule before save.
What it does is to automatically inject the date in the Status field of the iProperties. The example I have given below converts a date in format "10/29/2010 9:32:12 AM" to a status field in format "29-10-2010". You can change the order of the strings if you like. In order to display this new data format in the drawing title block, you will have to replace the <Creation date> property in the title block text by the <Status> property of the model. Hope this helps you workaround too stringent company standards.
Bob
10/29/2010 9:32:12 AM10/29/2010 9:32:12 AM
Dim NewDate As Date
Dim splitstr() As String
NewDate = Now
splitstr = Split (Newdate,"/")
Dim yearstr() As String
yearstr = Split(splitstr(2), " ")
mymonth = splitstr(0)
myday = splitstr(1)
myyear = yearstr(0)
iProperties.Value("Status", "Status")= myday + "-" + mymonth + "-" + myyear
Bob Van der Donck
Principal UX designer DMG group
Message 7 of 22
BrianForeman7947
in reply to: bobvdd
Thanks Bob. I would have to do that for EVERY date on a drawing file, not just the creation date (drawn date/rev date/eng date, etc.).  Way more bother than its worth.   The original specification dates back to 2D AutoCAD and pre Y2K issues.  The spec wants a date listed (29-OCT-10) for today.  OK, is that 2010 or 1910?  Alright, it isn't the issue now, but it will be.  The spec is what needs to change.  I agree with mgyvr that the spec should reflect today's systems and not dictate a particular format just because its always been that way.
Message 8 of 22
bobvdd
Agree. Time to change the spec ...
Bob
Bob Van der Donck
Message 9 of 22
in reply to: bobvdd
I respectfully disagree, and am looking for a similar capability. If you're doing work for clients from around the world, system date formats change. To stay cloistered in US format is limited thinking.
The system should always know the day, month and year regardless of the formatting and order or the elements. Excel allows for this type of format. A high-end tool like Inventor should be every bit as capable.
So there is your "very good" reason.
I hope Autodesk developers are reading this. I'm looking for a reasonable solution.
Message 10 of 22
isidrosarquis
in reply to: mcgyvr
I respectfully disagree too; I perceive that opinion is very closed-minded. There are some reasons:
a) I want my document seen in the same way in every computer that other people that opens it. I don’t want it is changing according the configuration of each computer that receive it, that would be totally out of any standard.
b) I've many different clients as the most companies have them, I neither want to force every one of my clients to change their standards and if they ask me to adjust my drawing to the standard that they use I must do it."Whatever the customer asks for".
c) All inventor fields formatting are very limited in inventor in compassion to Autocad that have no sense.
There would be some day when Autodesk improve those features.
Message 11 of 22
blair
in reply to: isidrosarquis
I have attached a link to the Inventor IdeaStation for this issue. The date format should be controlled by the Project File to allow companies to do work for different clients and have the date reflect the region and standards.
http://forums.autodesk.com/t5/inventor-ideastation/add-the-region-date-time-format-to-the-project-fi...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 12 of 22
Any news on this issue?
Seems completely outdated to not be able to customize the date format at will.
Message 13 of 22
SBix26
Agreed-- we recently started allowing Vault to manage our revisions, so have run into this for the first time.  We have a date standard (04-Apr-2017), which was chosen to eliminate any ambiguity.  It's achievable with Windows settings, but our drawing standard calls for all caps, and this can't be done.
As others have pointed out, it is ridiculous to force all users to set their computer system date formats the same, just as it would be to force them to use the same screen colors-- this is a personal usability preference.  The date format should be stored in the drawing file (and other files, too?), perhaps even individually for each field where a date is used as MS Office docs do.
Sam B
Inventor Professional 2017.3.1
Vault Workgroup 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Message 14 of 22
msklein
in reply to: SBix26
Best way to fix is to do away with Caps requirement. I think it's time for us as a whole to take a look as to the need to do all text in Caps. And before I start hearing "because we've always done it that way" I'm going to say "Just because we've always done it that way doesn't make it right and is a poor excuse. By the way I spent over 11 yrs on the board so I know why we did cap only on the board.
Message 15 of 22
msklein
in reply to: SBix26
deleted
Tags (2)
Message 16 of 22
in reply to: bobvdd
Bob,
I would like to ask if it is possible to change date format MM/DD/YYYY to MMM.DD.YYYY?
Please see attachment.
kelly.young has embedded your image for clarity.
Message 17 of 22
blair
You currently need to change the date on your operating system.
Delta Tau Chi ΔΤΧ
Message 18 of 22
in reply to: blair
Thank you blair! 😄
Message 19 of 22
in reply to: blair
Hi Blair,
I have another question:
It is possible to make the font in CAPITAL letter?
Message 20 of 22
blair
Good question, since the date is operating system setting dependant, you may need to find a O/S date format that is all capitals. You try to edit your drawing template and select/highlight the field and change it to capitals.
Delta Tau Chi ΔΤΧ
