I am using 2012 and am having a problem dimensioning to a virtual sharp.
On the above corner I select the straight edge on top or to the left of the corner. I then right click to bring up the intersect option but the only ooptions I get are :Done, Snap Settings, Zoom, Pan, and Help.
Do I have a setting off somewhere? Or is thie a location where the sharps don't work?
Thank you
Jim
Attach the file here.
JD,
I have attempted to upload the drawing 4 times and it keeps timing out. I will have my computer at home tomorrow with a faster connection and will try again then.
Thank you
CAD-1,
The problem is that when I Rmb I do not get the option "intersection". All I have is Done, snaps , zoom, pan, and help.
Yes there is a radius between the straight lines, this is often the case when a virtual sharp is needed so it should not be a problem.
Thank you
Jim
