Inventor General Discussion
Active Contributor
dexterdweller
Message 11 of 11 (49 Views)
Re: Cylinder piercing Cone constraint
03-14-2014 09:30 AM in reply to: JDMather
That's it; you are the Master!!
I was way over complicating that... I was trying to do it the same way I would have in SolidWorks I guess... and that is not about to happen.
In SolidWorks I would have slipped an additional part in there that was solely reference geometry. In this part have a sketch and attached UCS's to each point where I needed the pipes on the cone and drag and dropped them allowing them to automatically mate UCS/UCS. Each part with a sketch on it that can be used to do an assembly cut and do it on the assembly level. I seem to do this too often... Too many years of SolidWorks and not enough Inventor...
Thank you for all of your help it is greatly appreciated!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
